Fluid Mechanics Pressure Intensity Diagrams
An intensity diagram for a layer of fresh water atop salt water illustrates that the denser salt water will always be at the bottom due to its higher density. Pressure in fluids at rest increases linearly with depth, following the equation pressure = ρgh. When drawing the diagram, both fluids can be represented on the same graph, with their respective pressures labeled according to their depths. The pressure at any point below the surface will be the sum of the pressures from both fluid columns. Understanding this concept is crucial for solving related exam questions effectively.
feot09
I was wondering if anyone could please explain what an intensity diagram would look like if you had a layer of fresh water ontop of x amount of meters of salt water (or vice versa). What is the concept behind this? How could you draw it? The question keeps popping up in past exam questions but i can't seem to find a way to awnser it since i have never been taught intensity diagram with two different substance densitys. Is it complicated or am i making it complicated? Thank you very much!
Do you mean fluid at rest in different strata?? If so, heavier fluid(per unit volume or higher density) will be at the bottom.
Do you know how pressure varies in fluid at rest? Just write a general equation for pressure at a point.
Hint: pressure at a point at depth h = ρgh. Pressure at a point below depth h = ρgh + pressure due to second column below depth h
Ok so does that mean if i draw the pressure intensity diagram of salt and freshwater, salt water is always going to be at the bottom because of its higher density and they are put on the same pressure intensity diagaram but i just label their different forces at their respective places? Do they have the same or independent gravity center? Thank you so much, i just really need to understand thiis concept. Please bear with me
Correct. Think of why an air balloon rises up in water.
Pressure varies linearly with depth of fluid. Let's say there are two liquids of densities ρ1 & ρ212) with column height h1 & h2 respectively. Pressure at point below these two columns = ρ1gh1 + ρ2gh2.
Can you show what your attempt has been? It will be easier to help you that way.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
