Cylinder pulled by string on flat surface w/out slipping
highroller
1. The problem statement: a 100kg homogeneous cylinder of radius .3m. Starts at rest. Is pulled by a string wrapped around the cylinder coming off the top with a force of 500N.
Find the angular velocity after the cylinder has rolled one revolution?
The attempt at a solution: I= 4.5kg*m^2
circumferance=1.885m
work= 500*1.885= .5m(wr)^2+.5Iw^2 (using w for omega)
answer I get ... w=11.81rad/s
supposedly correct answer is 16.71
can someone please explain. I suppose the force could be doing rotational work as well but I'm having a hard time believing that the force does double the work because of where it is applyed.
My question is which answer is correct and WHY? thanks for any help
Welcome to PF!
Hi highroller! Welcome to PF! :smile:
(have an omega: ω and try using the X2 tag just above the Reply box :wink:)
Yes intial energy is zero, so work done = final energy. :smile:
But what is your .5m(ωr)2 supposed to be?
There's no extra mass … it's only a cylinder, with energy 1/2 Iω2 :wink:
the cylinder has both linear and rotational ke so the .5m(wr)^2 comes from .5mv^2 with v=wr
ah, sorry … i looked at your 500*1.885 and assumed that the axle was fixed. :redface:
Hint: how fast is the string moving? :smile:
Imagine someone pulling the string. In order to have the cylinder roll through one revolution, for what distance must they pull the string? (Don't forget that the string is unwinding as it's being pulled.)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
