Why are intermolecular HCl molecules among them not considered hydrogen bonds?
A hydrogen bond is defined as the attractive force between an electronegative atom and a hydrogen atom that is covalently bonded to another electronegative atom, typically nitrogen, oxygen, or fluorine. The discussion questions whether hydrochloric acid (HCl) exhibits hydrogen bonding. While chlorine is electronegative, its larger atomic size prevents it from forming strong hydrogen bonds with hydrogen due to insufficient proximity to create a significant dipole. Instead, the interaction between hydrogen and chlorine in HCl is more covalent in nature, as the high charge density of hydrogen can deform the larger chlorine atom, leading to weaker dipole-dipole interactions rather than true hydrogen bonding.
kashiark
A hydrogen bond is the attractive force between one electronegative atom and a hydrogen covalently bonded to another electronegative atom. Doesn't this apply to hydrochloric acid?
Chemistry news on Phys.org
http://en.wikipedia.org/wiki/Hydrogen_bond
It results from a dipole-dipole force with a hydrogen atom bonded to nitrogen, oxygen or fluorine.
Studying general chemistry? That statement was from wiki so basically, it's got to involve one of those elements.
Youd expect it to because Cl is pretty electronegative, but chlorine is also a very large molecule, so it basically can't get close enough to the hydrogens to cause any particularly strong dipole, and the hydrogen has a high charge density so it deformes the large Cl into a fairly covelant bond.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
