Cheap ml range liquid flow sensor
There is a discussion about finding affordable liquid flow sensors suitable for low-viscosity liquids like water. Participants mention various companies, including King Instrument and Weber Sensors, which offer flow meters at different price points, with some being significantly more expensive due to their industrial-grade specifications. A specific request for an inline sensor compatible with clear vinyl tubing that outputs 0-5V is noted, but it is suggested that such options may not be cheap. The conversation highlights the need for some electronics knowledge to integrate these sensors effectively. Overall, the search for economical flow sensors continues with recommendations for further research into specific models and applications.
miva
Hello,
I was wondering if anyone know any companies which sell directly these items because it seems many of the ones i am finding are for high end applications...
Any help would be much appreciated.
Note: no liquids are corrosive and low viscosity etc generally just water will flow through it
Please help
Miles
Lots of different kinds of flow meters what are you looking for and how much money do you want to spend?
http://www.kinginstrumentco.com/"
I have used meters from these people and was happy with them. I paid about $140 for a flow meter with max flow of 30ml/min. They can make them for even lower flow.
We also had http://www.webersensorsinc.com/" at max flow of 10ml/min but they cost ~$1200 each.
The flowmeter Integral is referring to is called a "rotameter". They're very cheap - I've seen them as low as ~$50. Try looking through http://www.mcmaster.com/#rotameters/=38ty37"as well.
thanks guys for the replies!
i'm more after a in line sensor, something that can ideally join to clear vinal tubing and produces a output something like 0-5V
any more ideas?
You are not going to find that cheap. Look at the Weber site. The meters I worked with had a 4-20ma output but could be ordered with 5V or 10V. You will need some knowledge of electronics to make it work.
Hi!
4-20 mA stuff really costs a lot as already pointed out. This is because 4-20mA is an industrial standard protocol, and the sensors are made to last.
If you tell us more about your application it might help.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
