Calculating K.E: 0.0136 J Solution
  • Thread starter Thread starter sfx81
The discussion focuses on calculating the kinetic energy of a mass attached to a turntable rotating at 1 revolution per second with a radius of 6 cm. The initial calculation of kinetic energy using the formula K.E = (1/2)mv² yielded 0.0136 Joules, but further analysis suggested the need to consider rotational kinetic energy. The moment of inertia for a point mass and the angular frequency were introduced, leading to a revised calculation of 2.841 x 10^-3 Joules for the rotational kinetic energy. The conversation also addresses how to incorporate the mass of the turntable into the calculations, highlighting the complexity of uniform mass distribution. The need for clarification on these calculations and their implications remains a key point of discussion.
sfx81
Hi, I am trying to calculate Kinetic energy of system where a mass m(0.20 kilogram) attached at one ond of turntable rotating at 1 revolution per second. The radius of turntable is 6cm.
Here I solve it, please correct
Kinetic Energy = (1/2)mv2
calculating velocity at 1 rpm, and radius = 6cm
so for circumfrance of circle = 2*pi*r
v = 2 * 3.14 * 6cm = 37.69 cm = 0.3769 meters/second
K.E = 0.5 * 0.20 * 0.372 meters
= 0.0136 Joules <=== Is this correct ?
Any help will be appreciated.
Thanks
You need to work out it's rotational kinetic energy.
I = m*(r^2)
I is the moment of inertia of a point mass rotating about a fixed point. Mass of turntable isn't mentioned so assume it is negligible.
E = 0.5*I*(w^2)
E is the energy of a rotating system, where w is angular frequency which is found by:
w = 2*(\pi)/T
Hi . So If I get it right
mass = 0.02Kg, radius = 6cm = 0.06 meter, frequency = 1 revolution per second
KErotation = I * w2
where w = angular velocity = 2 * pi * f , where f = frequency in revolutions per second.
I = m * r2
K.E rotation = m * r2 * ( 2 * pi * 1)2
= 0.02 * 0.062 * (2*pi*1)
= 2.841 * 10-3 Joules
If this is correct, then how do we equate in the mass of turn table (e.g 0.5 Kg) into equation ? Cause rotational kinetic energy deals with point mass around rotation axis, where as a turn table alone has uniform mass distribution along its surface ?
Thanks
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
