How Much Thrust Does a 1W Flashlight Emit?
  • Thread starter Thread starter jacobgong
    Thrust
A 1W flashlight emits thrust due to the momentum of light, which can be calculated using the equation for light's momentum. The force exerted by the flashlight is related to the wavelength of the emitted light, with 500nm light being specified in the discussion. When a perfect mirror is placed in front of the flashlight, it would receive the same amount of force due to the conservation of momentum, as light reflects off the mirror. Participants emphasize the importance of showing effort in calculations to facilitate learning. The thrust produced by such a flashlight is expected to be extremely small and negligible in practical applications.
jacobgong
What would be the thrust from a 1W light output flashlight, assuming light is not scatered at all.
I'm not sure but if it depends on the wavelength, assume it only emits 500nm light.
and if I were to put a perfect mirror right infront of this flashlight would the mirror receive the same amount of force?
please breifely explain how it's calculated. (the equation and the Plank's constant?)
Well, light has momentum, so you can just use the standard conservation laws and the equation for light's momentum to calculate any "thrust", or reaction force, you wish. As far as mirrors are concerned, remember momentum is a vector.
Welcome to the PF, Jacob. Per the PF Rules link at the top of the page, we shouldn't offer you help until you post the relevant equations and show some work/effort on your part. That's how we try to help you learn how to learn, eh?
well I can garentee you I'll never be asking about any homeworks. I only ask for personal interest. That's the reason for my simple numbers, because it's just a question i randomly made up.
it's not like I'm trying to make anyone to work for me or anything like that.
so you see if I didn't even try, and you tell me the answer, i don't benifit at all. and I know the answer is going to be so small it won't make any sense in this application.
