Mass of a planet using a satellite
To calculate the mass of planet X, the satellite's orbital radius must be determined by adding the planet's radius (5.78 * 10^6 m) to the satellite's altitude (530,000 m). The relevant formula, derived from Newton's law of gravitation, is 4π²r²/T² = GM/r, where T is the orbital period. The user initially calculated the mass as 5.246804357 * 10^17 kg but was unsure about the correct application of the radius. Understanding the relationship between gravitational force and centripetal force is crucial for solving such problems effectively. Clarity on these concepts will help in accurately applying the formulas to find the correct mass of the planet.
cruisx
A satellite circles planet X once every 99 min at a mean altitude of 530km. Calculate the mass of the Planet, if its radius is 5.78 * 10^6
So this is the Question i am having trouble with, these gravity questions are really killing me.
4 pi2R2/ T2 = GM/R
So i changed that equation in the following
4 pi2R3/ G T2 = M
and then i change the 99 minuets into seconds and then i change the 530Km into M . Now this is where a friend told me that i need to at 530 000m in the the given radius of 5.78 * 10^6. I couldn't understand why he said that though. So going on with what i was told i plugged everything into the equation and i got
5.246804357 * 1017Kg as the mass of the planet.
Now i have doubts about this because i didn't quite know what to do with the 530 000m. I hope someone can correct my mistakes and show me the right solution. These gravitational questions are really giving me a tough time today.
thanks.
If you don't understand that, then you don't understand the problem, and you are basically just manipulating formulas without understanding what those formulas mean. That would be very unfortunate. Physics is not about blindly applying formulas to calculate things. Physics is about understanding concepts and expressing them mathematically. Let me ask you something cruisx: Do you *understand* the main concept behind this problem? Do you know why the equality 4π2r2 / T2 = GM/R is true in this situation?
I'm not trying to pick on you. I'm only asking because, if you don't understand the actual physics, then I am willing to do my best to try and explain.
No, cepheid i am not fully understanding the actual physics behind that formula, i am have a bit of a hard time with Universal gravitation. Could you please explain to me if you have time?
Newton's law of gravitation states that if you have two masses m and M, separated by a distance r, then the strength of the gravitational force between them is given by the relationship:
F = \frac{GmM}{r^2}​
where r is the distance between the centres of the two masses. This is an important point that will come up later.
Now, if you have an object moving on a circular path, you can show (and I won't give the derivation here -- it is probably in your book) using entirely geometric arguments that that object must have an acceleration that always (at any instant) points towards the centre of the circular path. (That's what 'centripetal' means -- pointing towards the centre). You can also show that if the object moves with a constant speed v and its circular path has radius r, then the magnitude of this centripetal acceleration is given by a = v2/r. If the object has mass m, then Newton's 2nd law says that F = ma, and therefore the magnitude of the centripetal force is F = mv2/r. Now I want to point out that this is a kinematic requirement -- i.e. a centripetal force of this magnitude is required for any sort of uniform circular motion, but the equation doesn't tell you anything about what is causing that centripetal force. It could be because the object is tied to a string, or maybe it's under the influence of gravity, or maybe it is charged and experiencing an electrostatic force, or maybe there's friction, or...
In our situation, gravity is what is providing the centripetal force. The satellite moves in a circular path because the planet's gravity is constantly pulling on the satellite. This pull is in a direction towards the centre of the planet (and therefore towards the centre of the circular orbit). It is an example of a centripetal force. Now, if the satellite has mass m, then the centripetal force must have magnitude mv2/r. However, since the force is also the gravitational force of attraction between the planet and satellite, then Newton's Law of Gravitation says that its magnitude is given by GmM/r2. Since the centripetal force IS gravity in this situation, these magnitudes must be equal:
F_{\textrm{cent}} = F_{\textrm{grav}}
\frac{mv^2}{r} = \frac{GmM}{r^2}​
The mass of the satellite, m, cancels from both sides of the equation (which means that the properties of the orbit don't depend upon how big the satellite is!). We are left with:
\frac{v^2}{r} = \frac{GM}{r^2}​
Multiplying both sides of the equation by r, we get:
v^2 = \frac{GM}{r}​
How can we figure out the speed, v, of the satellite? We know how much time the satellite takes to go around in its orbit (which is the orbital period, T). This is given in the problem. Speed = distance/time. So if we can just figure out how much distance is covered in one orbit, we can calculate the speed by dividing that distance by T. Well, the orbit is a circle of radius r. Therefore, from basic geometry, the distance around the orbit is given by 2πr. Speed = distance/time, which means that v =2πr/T. Plugging this expression for the velocity into the previous equation, the result is:
\left(\frac{2\pi r}{T}\right)^2 = \frac{GM}{r}​
\frac{4\pi^2 r^2}{T^2}= \frac{GM}{r}​
THAT's why this equation is applicable to the problem. Now we just have to solve for M, the planet's mass. We need to calculate r, the orbital radius. Here comes the important point. Remember that in Newton's law of gravitation, the distance r, between the two masses, is the distance between their centres. Therefore, r is the distance between the satellite and the centre of the planet. THAT is why r is given by:
r = radius of planet + height of orbit.
I hope that that clears things up.
v^2 = \frac{GM}{r}​
THAT's why this equation is applicable to the problem. Now we just have to solve for r, the orbital radius. Here comes the important point. Remember that in Newton's law of gravitation, the distance r, between the two masses, is the distance between their centres. Therefore, r is the distance between the satellite and the centre of the planet. THAT is why r is given by:
Yes that makes much more sense, thanks for the explanation. So you are saying that r is the distance between their centers so something liek this?
http://img196.imageshack.us/img196/709/gravl.jpg
Thanks, i am going to check over my solution one more time and see if i can come up with the correct answer.
[/URL]
Yeah.
Well, good luck. Once you have the concepts down, it's just algebra from there.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
