Proof of sen² 25º + cos² 45º + sen² 65º = 3/2
  • Thread starter Thread starter Fanekaz
    Cos Proof
The discussion focuses on proving the equation sin² 25º + cos² 45º + sin² 65º = 3/2. Participants clarify that "sen" is a mispronunciation of "sin," and the notation sin² x indicates the sine of x squared. The value of cos 45º is confirmed to be 1, which is relevant for the proof. There is some confusion regarding the notation, but it is explained that it simplifies writing. The conversation emphasizes understanding the squared terms in trigonometric functions.
Fanekaz
Show that sen² 25º + cos² 45º + sen² 65º = 3/2
cos 45º= 1
I get confused with the ² on the cos and sen...
Hi Fanekaz! :smile:
(btw, it's sin, not sen :wink:)
It just means that the whole thing is squared …
so sin2x means (sinx)2
(pronounce it "sine squared of x")
it saves writing brackets. :biggrin:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
