Calculating Max Compression of Massless Hookslaw Spring
The discussion focuses on calculating the maximum compression of a massless Hooke's law spring when a mass is dropped onto it from a height. The energy conservation equation mgh = -mgs + 0.5ks² is central to the problem, where the variables represent gravitational potential energy and spring potential energy. Participants discuss deriving the spring constant k in terms of other parameters to facilitate solving for maximum compression. There is confusion about the relevance of the spring constant and its application in the problem. Understanding the spring constant's role can help clarify the relationship between the mass, height, and spring compression.
joemama69
A massless hooksw law spring has a unstretched length of L, when a mass m is ploaced on it, and slowly lowered until the mass is at rest, the spring is queezed to a length of x. the mass is then dropped on the spring from a height of h, use energ methods
what is the length of the spring at maximum compression as a result of the mass dropping on it
mgh = -mgs + .5ks2
s = -mg + or -(((mg)2 - 4(.5k)(mgh))/k).5
if this is correct
The question is worded aquardly, but I think you're on the right path with your firse equation. Now you need to write the spring constant k in terms of other parameters you have in your problem.
Also, you get two anilytical solutions. Can you think which sollution is correct? What does your non-physical solution correspond do?
what would be the benefit from solving for the spring constant
it asks for the length of the spring at compression s
That way the spring constant is expressed in terms of other known parameters.
k = (2mgs - 2mgh)s2 = 2mg(s-h)/s2
i still don't understand how that helps, what would i use it for now
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
