How can Lenz's Law be derived?
Lenz's Law states that an induced current opposes the change causing it, but deriving it mathematically is challenging. The discussion highlights that Lenz's Law is more of an observed fact rather than a derivable principle, akin to the right-hand rule in electromagnetism. It is suggested that the law is a consequence of the negative sign in Maxwell's equations, which dictate the direction of induced electromotive force (EMF). The conversation also touches on the relationship between Lenz's Law and the conservation of energy, emphasizing that violating this principle would contradict the law. Ultimately, Lenz's Law is recognized as a fundamental aspect of classical electrodynamics.
acimarol
Heinrich Lenz postulated in 1834 the following law;
"An induced current is always in such a direction as to oppose the motion or change causing it"
I have checked many undergrad/grad-level textbooks for a derivation, but they all just state Lenz's Law without derivation as if it were a universal law like the conservation of energy.
Can anyone help me with a derivation of Lenz's Law?
I don't know if you can really "derive" something like Lenz's Law.
Do you mean mathematically? because I don't know if that's necessarily possible,
its just an observed fact that if you (for instance) change the magnetic flux through a solenoid a current will be induced that will create a Magnetic field to oppose the change.
Perhaps intuitively you could think of it as a solenoid resisting changes to its B fields,
and following that logic it can be seen as a result of conservation arguments.
Its sort of like asking to "derive" the observed fact that a moving charged particle
feels a force perpendicular to the velocity of the particle and the B field;
its just what happens.
Yes, I am asking for some sort of mathematical proof. But what you say is reasonable, and I see where you are coming from.
Let's say a magnetic dipole is moving toward a coil with a constant velocity. I was mainly wondering if the part of Lenz's Law that says the induced magnetic field will oppose the motion of the magnet is a consequence of conservation of energy? Or am I interpreting Lenz's incorrectly, and it actually does not state anything about opposing the motion of the magnetic dipole?
jtbell said:
Lenz's Law is the conseqence of the minus sign in the third of Maxwell's equations, which are the fundamental starting point for classical electrodynamics:
http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/maxeq.html
I think you've got it a bit backwards, the minus sign I think is the consequence of the experimental fact. All it does is give the the direction of the E field, as you may remember are conventions for picking the directions of E and B fields are arbitrary. Frankly I think asking to derive Lenz's Law is like asking to derive the right hand rule, its just the result of an arbitrary choice of picking a direction. Reverse the directions and suddenly the "Law" says that the induced EMF supports the change in flux.
No, you cannot get the EMF to support the change in flux, that would violate energy conservation at the very least. If you changed the handed-ness convention consistently throughout the equations, you should preserve Lenz's Law.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'A scenario of non uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
