How to Calculate Forces Between Two Boxes on a Frictionless Surface?
  • Thread starter Thread starter DeathByVirus
    Forces
To calculate the forces between two boxes on a frictionless surface, the total mass of the system is 2.5 kg when a 5.0 N force is applied to Box A, resulting in an acceleration of 2.0 m/s² for both boxes. The contact force between the boxes is determined by the acceleration of Box B, which is influenced by the reaction force from Box A. While initially thought to be equal to the applied force, the correct contact force is calculated to be 2 N, as Box A pushes Box B with this force. The discussion highlights the application of Newton's laws to understand the interaction between the two boxes.
DeathByVirus
Two boxes stay beside each other touching on a flat ground.
The ground is frictionless.
________ _______
|~1.5KG`||~1.0KG|
|~BoxA~||~BoxB~|
|_______||______|
A) If 5.0N
of force is applied to BoxA what is the acceleration of BoxB
B) During this, what is their contact force?
M1 = 1.5KG
M2 = 1.0KG
Fapp = 5.0N
a) so what i did was add the boxes together so total mass is 2.5KG
then the Fnet will equal applied force since no other forces are relevant
so by second law
Fnet = ma
5.0 = 2.5a
a = 2.0 m/s^2
the second box will accelerate at 2.0 m/s^2.
b) since only applied force of 5N is on BoxA
the third law states that for every action there is an equal and opposite reaction
so if the boxA is pushed by 5N that means boxB will back on boxA with 5N
therefore the contact force = applied force = 5.0 N
did i do it right?​
Hi DeathByVirus, welcome to PF.
Your argument is net correct.
Both the blocks are moving with the same acceleration.
The applied force pushes block A. Block A acts on block B. Block reacts on Block A.
Net contact force pushes the block B towards right. You know the mass of the block B and its acceleration. Find the contact force.
the contact force isn't 5?
its ...
fnet = ma
= 1.5 x 2
= 3 N
or is it..
fnet = ma
5 = 1.5 a
a = 3.33 for box A alone
then the net force box A pushes box B with
fnet = 1.5x3.33
which will round back to
fnet = 5N
Okay, we know that Fnet is equal to 5, since it is the only force significantly acting on the system. But we also know that if
Fnet = m1a + m2a = (m1+m2)a, then the force effecting m1 cannot be 5, unless m2 has no mass. By Newton's third, we know that m1 is 'held back' by the reaction force from m2. Meaning, the force on m1 should be 5-(reaction force) = m1a; and again, by Newton's third, this force is equal and opposite to the force from m1 to m2.
wisvuze said:
the Fnet force is 5, so Fnet = F1 + F2.
1.5a
1a
1.5a+1a = 2.5a = 5, a = 2
then the contact force from block 1 to block 2 should be 2 N
if a = 2
then fnet(boxA) = m(boxA)a
fnet(boxA) = 1.5x 2
= 3N
shouldnt it be 3?
DeathByVirus said:
if a = 2
fnet(boxA) = 1.5x 2
= 3N
shouldnt it be 3?
I edited my post to include some explanation, read above
Fnet = m1a + m2a = (m1+m2)a, then the force effecting m1 cannot be 5, unless m2 has no mass. By Newton's third, we know that m1 is retarded by the reaction force from m2. Meaning, the force on m1 should be 5-m2a = m1a; and again, by Newton's third, this force is equal and opposite to the force from m1 to m2.
so you're saying the force on m1 should be 5-m2a = m1a and
the force on m2 is 5 - m1a = m2a?
but m1a represents the net force on mass 1...it allows mass 1 to accelerate and also is the force that it pushes mass 2 with?
sorry ..im not very smart
oops, I meant that m1a = 5 - some reaction force/contact force not m2a, sorry
huh? now I'm just confused all over again
m1a=5- what reaction/contact force?
then what happens to m2a?
the reaction force is the force equal to the contact force pushing back onto m1, so it would have had a force of 5 N if it weren't for that block:
5N ---> [Block 1] <--- ---> [Block 2]
You see that Block 1 pushes onto Block 2, but by Newton's third law, Block 2 exerts an equal but opposite force back onto Block 1, giving the equation m1a = 5 - reaction force
ah.. i see =p thank you very much...i just lost 3 marks on my test (:
it's okay :), so then since the reaction force is equal to the contact force, m2 is pushed by the contact force
Forces from the applied force to Block 2
5N ---> [Block 1] ---> [Block 2]
we know that m1a = 5 - reaction force
m1a = 3 , 3 = 5 - ReactionForce, ReactionForce = 2, but Reaction Force = Contact Force
so m2a = Contact force, since there are no other forces involved.
So m2a = 2
Now we can see that F net = 5 = m1a + m2a = 3 + 2
So m2a = 2
lol i think I am getting it (:
great...i now i have a 95 ish in phys >.>
