Entropy Question: Debye's Law & Heat Capacity of Diamond
  • Thread starter Thread starter Jerzey2Atl
    Entropy
The discussion revolves around calculating the entropy change of a diamond when heated at constant volume from 10 K to 350 K, using Debye's law for molar heat capacity. The user seeks guidance on which entropy equation to apply, expressing confusion over the presence of volume terms in equations for constant volume and constant pressure processes. They reference various equations, including one that suggests the entropy change can be calculated using the formula ΔS = Cv * ln(T1/T2). The user outlines their thought process, noting that at constant volume, the internal energy change (dU) equals the heat transferred (dq), leading to the conclusion that the entropy change can be integrated over the temperature range. They also mention the need to adjust the molar heat capacity based on the number of moles of carbon in the diamond.
Jerzey2Atl
Hi, this is my first time using this forum. I have a question dealing with entropy and thermodynamics.
Here goes:
According to Debye’s law, the molar heat capacity at constant volume of a
diamond varies with temperature according to the relation
Cv = (12*pi^4*R / 5) x (T / TD)^3
where TD = 2230 K. For a diamond of mass 1. 20 g, what is its entropy change when it is heatedat constant volume from 10. 0 K to 350 K? The molar mass of carbon is 12. 0 g/mol.
I know Ihave to first fidn the molar mass, but I am not sure of which form of the entropy equation to use. Any help is appreciated.
Chemistry news on Phys.org
it's been a long time since i took pchem, but I googled and might have found an equation that deals with what you are talking about
http://www.grc.nasa.gov/WWW/K-12/airplane/entropy.html
has this down the page
s2 - s1 = cv * ln ( T2 / T1) + R * ln ( v2 / v1)
i don't know why they say "constant volume" then have two volumes in the equation
just like the similar one for "constant pressure" has two pressures
s2 - s1 = cp * ln ( T2 / T1) - R * ln ( p2 / p1)
hmm, well it all goes to zero anyway so why bother?
http://www.physics.carleton.ca/~hardy/75342/Lect_16/Lect_16.html
here they have [delta]S = Cv * ln(T1/T2)
i doubt i helped :)
This may be very wrong, but this is how I'd do it:
T = Temperature
S = Entropy
U = Internal Energy
dq = Heat transferrd to the system
dw = Work done on the system
Cv = Constant volume heat capacity
dU = dq + dw , but since no work is being done on the system dU = dq.
At constant volume, Cv = (dU/dT) so dU = Cv*dT
At the same time, dS = (dU/T) (at constant volume) so dS = (Cv*dT)/T. If you integrate this between T=10 and T=350 then I reckon that's the answer (not forgetting to divide the molar heat capacity you're given by ten, as this is the number of mols of carbon in the question.)
However, bear in mind that I'm an idiot.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
