Phase Factor in wave propagation (lossy medium): does the distance matters?
In wave propagation through a lossy medium, the phase factor (BETA) represents the phase shift per meter, while the attenuation factor (ALFA) quantifies signal loss over distance. The relationship between distance and phase shift is expressed as BETA multiplied by the distance traveled, indicating that phase shift accumulates with distance. However, unlike attenuation, which is calculated using the formula 8.69*ALFA*d, the phase factor does not have a direct distance-dependent formula for attenuation in dBs. The overall wave propagation can be described using a complex propagator, γ = α + iβ, where α represents attenuation and β represents phase shift. Understanding these relationships is crucial for analyzing signal behavior in lossy media.
Ionito
In the electromagnetism theory, the phase factor or constant (usually BETA) in wave propagation for lossy medium has the unit rad/m.
I understood that it must be interpreted as the amount of phase shift that occurs as the wave travels one meter.
However, differently of the attenuation factor (usually ALFA), I cannot see examples relating the phase factor to the distance. In other words, we can see the signal attenuation as the form of 8.69*ALFA*d, where d is the distance between the sender and the receiver. However, this distance "d" is not used in conjunction with the phase factor BETA. Is it right?
Can anyone provide me a complete example of the total attenuation (in dBs), given ALFA, BETA, frequency, and distance d, for a plane wave propagating in a lossy medium?
Thanks
Yes, the phase factor appears in the wave equation as beta(phase shift) multiplied with the distance in the direction of wave propagation.i.e if wave is traveling along z direction then phase factor = beta(z)
along with the time dependence wt.
beta is radians per meter,this multiplied with distance gives the phase shift in radians.
See the Definitions section of
http://en.wikipedia.org/wiki/Phase_constant#Phase_constant
The propagator in transmission lines is complex; γ = α +iβ. Alpha (α) has dimensions of nepers per meter. Beta (β) has dimensions of radians per meter. The attenuation in dB is 8.686·α·d.
Bob S
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
