FTIR Machine: Interference of Blackbody Radiation Source
  • Thread starter Thread starter physical101
    Ftir Machine
In FTIR spectroscopy, the blackbody radiation source emits a broad spectrum of infrared frequencies. These frequencies are split at the beam splitter, where half is reflected and half is transmitted. The reflected beam returns from a fixed mirror, while the transmitted beam is altered by a moving mirror before recombining at the beam splitter. This interference of the two beams creates a resultant wave that passes through the sample and reaches the detector. Ultimately, all frequencies from the blackbody source contribute to the final detected signal.
physical101
Hi there sorry to keep bombarding you all with these stupid questions but I just can't picture it in my head. In a FTIR machine when the blackbody radiation source is split at the beam splitter and half the frequencies are retarded before making a resultant wave and passing throught the sample and reaching the detector, would I be correct in thinking that all of the frequencies emitted from the blackbody radiation source interfere to produce one resultant wave which is then detected at the detector?
Well FTIR spectrometers have a infrared source(IR), has a broad spectrum, first goes to the beam splitter then 50% is reflected and transmitted. The reflected beam is reflected back by the fix mirror and the transmitted beam is reflected by the moving mirror to the beam splitter. Two beams interfere at the beam splitter then go through the sample.
