Energy considerations in strings
  • Thread starter Thread starter aim1732
    Energy Strings
The discussion revolves around a physics problem involving a block hanging from a string, where the block's weight causes an extension 'l'. The elastic potential energy (P.E) is noted to be half of (M*g*l), while the loss in gravitational P.E is (M*g*l), raising the question of where the remaining energy goes. One participant suggests hysteresis as a possible explanation, but another clarifies that the potential energy for a string obeying Hooke's law is YAl^2/2L, with maximum tension equating to M*g for equilibrium. The conversation highlights confusion over energy calculations and references a textbook for clarification. The thread emphasizes the importance of understanding energy transformations in elastic systems.
aim1732
1. Homework Statement
The problem concerns a block(mass M) hanging from a light string attached to a fixed support, that is pulled down with a force of the block's weight that produces an extension of 'l'.
2. Homework Equations
The elastic P.E is half of (M*g*l).However the loss in gravitational P.E is (M*g*l), The question is where does the other half go?
3. The Attempt at a Solution
My guess is hysterisis as in rubber.
Where did you get this from? This is not the potential energy for a string that obeys hooke's law.
The p.e is YAl^2/2L. However F=YAl/L. Here the maximum tension here is M*g as the block is supposed to hang in eqilibrium. Hence half of M*g*l. Most textbooks abbreviate it as half of max.tension multiplied into extension.
As for the info it is from The Concepts Of Physics.
Ah my mistake, I am quite rusty on this sort of stuff unfortunately. Hopefully someone else can help you here.
