Electric force magnitude of NH3
The discussion centers on calculating the electric force magnitude acting on H1 in the NH3 molecule, structured as an equilateral tetrahedron. The user outlines their approach, including the setup of vectors for forces from H2, H3, and N on H1, and uses trigonometric functions to resolve components. They express confusion over the expected cancellation of the x and y components, which should sum to zero, indicating a potential error in their calculations. The user seeks assistance in identifying where their calculations may have gone wrong. The conversation highlights the complexities of vector addition in electrostatics within molecular structures.
EV33
The structure of NH3 the molecule is approximately that of an equilateral tetrahedron, with three H+ ions forming the base and an N3− ion at the apex of the tetrahedron. The length of each side is 1.64 10-10 m. Calculate the magnitude of the electric force that acts on each ion. (Let the H+ ions be in the x-y plane with H1 at (0, 0, 0), H2 at (a, 0, 0), and H3 (a/2,(a*sqrt(3))/2,0), and the N is at (a/2,a/(sqrt(3)*2),a*sqrt(2/3))
where a = 1.64 10-10 m. To simplify our calculations we'll set (ke^2)/a^2 = C = 8.56 10^-9 N. Use the following variable as necessary : C.)
Find the magnitude of force on H1
(K* lq1*q2l)/r^2=F(E)
First of all after sketching a little diagram I concluded that the force of h2 on h1 was < - ,0,0>, h3 on h1 <-,-,0), and N on h1 <+,+,+>. Made these conclusions by looking at the direction the force would be. In the end I used these signs to give my magnitudes direction in order to add the vectors.
I found the distance between them all from h1 by using the distance formula. They have the same distance which is "a".
Then I set up triangles for them all except the first one because it is pushed straight down the x axis.
So for h2 on h1 I got (Ke^(2))/a^(2)<-1,0,0>
For h3 on h1 I got a triangle with a side in the x direction with a length of a/2 and the side in the y was (a*sqrt(3))/2. So I used tan(o/a)=30 degrees.
So I took the sin and cos of 30, and figured I needed to multiply my force by 1/2 to get the x comp, and root3 over 2 to get my y comp.
(Ke^(2))/a^(2)<-.5,-sqrt(3)/2,0>
Then for my N on h1 I did the same process and got
(3ke^2)/a^2<sqrt(3)/2,.5,.8164965809>
Then I added all my vectors together.
<(3^(3/2)-1-.5, 1.5-sqrt(3)/2, 3(.8164965809)>
The x and y component are apparently supposed to both be zero but I don't get them cancelling out.
Does anyone see where my error occured? Or at least can anyone tell me if I am taking the right steps.
I cleaned up my post a little bit. so hopefully it is understandable now.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
