Determine limiting behavior as t goes to infinity(Differential Equation)
  • Thread starter Thread starter Raziel2701
    Behavior
Raziel2701
Determine the limiting behavior of solutions as t \rightarrow \infty, for all possible values y_0 = y(0)
\frac{dy}{dt}=4-y^2
I've obtained the constant solutions, they are -2 and 2. I sketched dy/dt to determine the monotonicity, and found that the constant solution 2 is stable. My question is whether this stable solution is what determines the behavior as t goes to infinity.
I just started taking differential equations and I'm trying to get used to the language and the nature of the questions. Since 2 is a stable solution, that should mean that all initial values of y should go to 2 as time passes correct?
No. A solution doesn't have to approach the stable solution unless it starts out near the stable solution. Otherwise, it might just go to infinity.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
