Riemann Stieltjes Integral help
  • Thread starter Thread starter prudens2010
    Integral Riemann
The discussion focuses on finding the Riemann-Stieltjes integral of the function f defined as x for 0 ≤ x ≤ 1 and 1 for x > 1, with alpha defined as x^2 for 0 ≤ x ≤ 1 and 1 for x > 1. Participants emphasize using the definition of the Riemann-Stieltjes integral, noting that the problem can be simplified to an ordinary Riemann integral. The differential dα is identified as 2xdx for the interval 0 ≤ x ≤ 1 and 0 for x > 1. This leads to a straightforward calculation for the integral over the specified range. The discussion seeks clarity on any potential misunderstandings in the integration process.
prudens2010
Code:
Let f =
x, for 0<=x<=1
1, for 1<x
alpha =
x^2, for 0<=x<=1
1, for 1<x
Find Integral (f) d(alpha) -- from 0 to 23
pls help!
Mathematics news on Phys.org
prudens2010 said:
Code:
Let f =
x, for 0<=x<=1
1, for 1<x
alpha =
x^2, for 0<=x<=1
1, for 1<x
pls help!
Use the definition of the R-S integral. The answer should pop right out unless I'm missing something. Where does the problem lose you?
This case easily translates into an ordinary Riemann integral.
dα = 2xdx, 0≤x≤1
dα = 0, x>1
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
