How many stars in our galaxy if they had the mass of our Sun.
The discussion revolves around estimating the mass of the Milky Way Galaxy based on the Sun's orbit. The Sun is approximately 30,000 light years from the center and completes a rotation every 200 million years. The gravitational acceleration formula, g = GM/r^2, is referenced, along with the centripetal acceleration formula, a = v^2/r. An attempt to calculate the acceleration yielded a small positive value, indicating the mass distribution is concentrated in a central sphere. The ultimate goal is to determine how many stars, each with the mass of the Sun, would exist in the galaxy based on this mass estimation.
balletgirl
The Sun rotates about the center of the Milky Way Galaxy at a distance of about 3.00x10^4 light years from the center (1ly= 9.50x10^5 m). If it takes about 200 million years to make one rotation, estimate the mass of our galaxy. Assume the mass distribution of our galaxy is concentrated mostly in a central uniform sphere. If all the stars had about the same mass as our Sun, how many stars would there be in our galaxy?
I have no clue, the most common equation I use is g=GM/r^2 and a=v^2/r.
I do not know where to start.
Treat the galaxy as if it was a planet that the sun was orbiting.
Well, g is just gravitational acceleration, and is the a in a=v^2/r... but there's an equation missing.
a=\frac{4 \pi^2 r}{T^2}
Okay, so I did T= 200,000,000 yrs = 6.31x10^15 s
& R= 2.85x10^20
a=4pi^2*r/T^2
a= 4(3.14)^2*(2.85x10^20)/(6.31x10^15s)
a=39.4(2.85x10^20)/3.98x10^31
a= 2.81x10^-10
I doubt this is right since it is negative
No it's not... the exponent is negative, but the number is positive, just very small. And it should be small...
