Insulating Spherical Shell Potential Problem question
ramuramu
I have a question about an upper-division E&M HW
problem I'm stuck on. Any help would be GREATLY APPRECIATED!
Problem Statement:
An insulating spherical shell of radius R was set up to have a potential
on its surface of V=A*cos^2(theta), where A is a constant. The potential
at a distance very far away from the shell is defined to be zero.
(a) Find the potential V(r,theta) both inside and outside the shell.
E=-(grad)V
Since E=-(grad)V , I took the gradient in spherical coordinates of the V expression above
and got
E={[(2*A)/R]cos(theta)sin(theta)}theta-hat
for the E field on the surface of the shell. I then let R become the
variable r and tried to do the line integral from "infinity" to R
to get the potential outside the shell. But this involves a dot product with dr
which is orthogonal to theta-hat so I got ZERO! which certainly
doesn't make sense...I would REALLY appreciate any advice someone might have on
this problem!
Think carefully about what you're doing here.
Here's how I have read the question: You have a charged insulating spherical shell and no other sources of charge. You know the potential on the shell; deduce the potential at all other points.
Now the equation E=-grad(V) tells you how to get the electric field from the potential. I couldn't follow exactly what you were doing but it seemed like you calculated the electric field along the surface of a shell (you don't know what it is perpendicular to the shell yet) trying to add together infinitely many spherical shells to find the electric field of a solid sphere of infinite radius?
I think you need to consider general techniques for obtaining the potential due to a charged spherical shell, knowing the potential on the surface of the shell.
THANK YOU very much for your response.
Yes, I agree. I think I need to solve Laplace's Equation in spherical subject to the
boundary conditions:
(i) Vin = Vout
(ii) (dVin/dr - dVout/dr)|r=R = -(surface charge density)/epsilon-knot
(iii) As r-> infinity , V-> 0
Does this sound right to you?
Thank you so much again in advance!
I solved the problem using Laplace's Equation - the only problem is the Dielectic aspect of the shell. I suppose my boundary condition (ii) above:
is wrong? Should I just change the epsilon-knot to the epsilon of the dielectric surface?
Although that doesn't seem to make too much sense to me. If there's no dielectric
VOLUME then does it not "matter" and I should just use epsilon-knot for the vacuum around?
Anyway, thank you so much again for your help! I REALLY appreciate it!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
