How do I rearrange this equation for T?
  • Thread starter Thread starter mandy9008
To rearrange the equation Δy = Voy t - 1/2 g t² for T, it can be transformed into the standard quadratic form: 1/2 g t² - Voy t + Δy = 0. This resembles the quadratic equation ax² + bx + c = 0, allowing the application of the quadratic formula. By identifying a = 1/2 g, b = -Voy, and c = Δy, the quadratic formula can be used to solve for T. The solution will yield two possible values for T, reflecting the nature of quadratic equations. Understanding this method is essential for correctly isolating T in the given equation.
mandy9008
I need to rearrange the following equation for T. I haven't done this for so long, that it has slipped my mind.
change in y = Voy t - 1/2 g t2
t = (change in y + 1/2) / (Voy - g)
I know this is completely wrong, but I can't, for the life of me, figure it out. :/
mandy9008;2761327 [h2 said:
The Attempt at a Solution[/h2]
So you have Δy= v0t-1/2gt2
this can be written as 1/2gt2-v0t+Δy = 0
doesn't this look similar to at2+bt+c=0?
now apply the quadratic equation formula.
