Is Melting Tyvek Safe? Bonding for Projects
  • Thread starter Thread starter e2e8
    Melting
Using Tyvek for bonding projects raises concerns about the safety and effectiveness of melting the material together. Tyvek, a type of polyethylene, is a thermoplastic that can be melted without decomposition if the temperature is kept low. However, melting Tyvek alters its crystalline structure, which can compromise the material's original properties. Therefore, while melting may be a feasible method for bonding, it is essential to consider the potential changes in strength and durability of the melted areas. For safe handling and application, consulting the Material Safety Data Sheet (MSDS) is recommended.
e2e8
I am using Tyvek for a project and need bond it together. I thought melting it together would the best way. Would that be safe.
MSDS:
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBwQFjAA&url=http%3A%2F%2Fwww.conservationresources.com.au%2Fhtml%2Fhome%2Fhelp_info%2Fdownloads%2FTyvek_MSDS.pdf&ei=kGdITJGjGoL78AaupfyDDw&usg=AFQjCNF4m6O5r5t9wW8q_DcLOysYAtG4uw&sig2=ElLraPvAmuC24EUnycLuuA
http://www2.dupont.com/Tyvek/en_US/tech_info/test_results.html
Chemistry news on Phys.org
It's a sort of polyethylene, which is a thermoplastic, meaning it can be melted without it decomposing, as long a you keep the temperature low.
However, this will lead to changes in the crystalline structure, so don't count on retaining the material properties in the melted part.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
