RGB Tristimulus Graph: Negative Red Values Explained
  • Thread starter Thread starter Cyb3rGlitch
    Graph
Cyb3rGlitch
Hey guys,
I'm just trying to get my head around the RGB tristimulus graph, as follows:
[URL]http://cnx.org/content/m18092/latest/trist.png[/URL]
Why are there negative values for red? What does it mean?
I'd appreciate it if someone could help. And no, this isn't a homework question, it's part of my Computer Graphics course notes, and I'm having trouble understanding this particular concept.
Thank you!
Refer to a http://www.tftcentral.co.uk/images/gamut/ciechart.jpg" .
'Pure' wavelengths are the convex edge of the diagram. So the tristimulus values (435.8nm, 546nm, 700nm) are three points on this edge, and the colors they can represent are the points inside that triangle. Not every color is inside it, which is why you can have negative values.
Note that the chart itself isn't really accurate for this reason. And your computer monitor only displays an even smaller gamut (see e.g. http://jkphoto.net/attach/1/1292499025.jpg" image showing some common color spaces)
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
