How to Draw Shear Stress-Strain Curves for Liquefaction Resistance of Sand?
The discussion focuses on drawing shear stress-strain curves for liquefaction resistance of sand using shaking table tests. The user seeks clarification on calculating shear stress and strain, proposing a formula involving mass and acceleration at various depths. Key points include the distinction between force and stress, the importance of defining terms, and the role of water content in granular materials like sand. There is also a mention of using accelerometers to measure the acceleration of both the saturated sand and the container wall for accurate data. The conversation emphasizes the need for correct conceptual understanding and precise measurements in the analysis.
hooman_m
Dear colleagues
I`m working on liquefaction resistance of sand utilizing shaking table tests.
i want to draw shear stress-strain curves for each test and i need help from you,my Physicist colleagues. my model container is 200*70*50cm and i`ve put acceleration transducers at depth 7,21 and 35cm from top.I have a general idea of how i can draw shear stress-strain curves using time history of acceleration but i`m not sure about it.i would be more than happy if you can help me.
I guess for determining shear stress at any point i can use t=sigma miai from top to the point of interest.which t is shear stress ,mi is mass at any point and ai is acceleration at any point.and i simplify the process by assuming acceleration is linear through depth.am i right about the process? and i`m so confused how i can determine shear strain at any depth.
i would appreciate your help
First you need to get your concepts correct.
Force (not stress) = mass x acceleration, .
Stress = force/area
Second it is a good idea to define all the terms in your proposed formula. What is sigma?
You also need to realize that in a granular material such as sand the mechanism for carrying stress depends upon the water content.
What do the accelerometers measure the acceleration of? The sand or the container wall?
τ=∑〖m_i a_i 〗/area of the face of container wall and sand is saturated.i put the mentioned accelerometers into the sand so it measures the acceleration of saturated sand.i also measure the acceleration of container wall with another accelerometer if it helps.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
