Distance Needed for Electrostatic Force Between 2 Protons
To determine the distance required for the electrostatic force between two protons to equal the weight of one proton, the relevant equations include Coulomb's law and the gravitational force equation. The electrostatic force can be calculated using F = k * (q1 * q2) / r², where k is Coulomb's constant, q1 and q2 are the charges of the protons, and r is the distance between them. The weight of a proton can be found using W = m * g, where m is the mass of the proton and g is the acceleration due to gravity. By setting the electrostatic force equal to the weight of a proton, one can solve for the required distance r. This calculation reveals the significant distance needed for the electrostatic force to match the gravitational force acting on a proton.
Roxiney
How far must two protons be placed on the Earth’s surface for there to be an electrostatic force between them equal to the weight of one of the protons?
Show some attempt. What are the relevant equations you need to consider?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
