To calculate the volume of a celestial body with a diameter of 2280 km, first determine the radius by dividing the diameter by two, resulting in a radius of 1140 km. The volume can then be calculated using the formula V = (4/3) * π * r^3. Substituting the radius into the equation provides the volume of the body. This method effectively utilizes the relationship between diameter, radius, and volume for spherical objects.
#1
pwats17
The diameter of some celestial body is 2280 km. What is the volume of this body?
Well we know that the radius is half the diameter, right? We also have an equation that relates volume to radius of a sphere. It is V = (4/3) * pi * r^3, where r is the radius. Hope that helps.
Starting with the mass considerations #m(t)# is mass of water #M_{c}# mass of container and #M(t)# mass of total system
$$M(t) = M_{C} + m(t)$$
$$\Rightarrow \frac{dM(t)}{dt} = \frac{dm(t)}{dt}$$
$$P_i = Mv + u \, dm$$
$$P_f = (M + dm)(v + dv)$$
$$\Delta P = M \, dv + (v - u) \, dm$$
$$F = \frac{dP}{dt} = M \frac{dv}{dt} + (v - u) \frac{dm}{dt}$$
$$F = u \frac{dm}{dt} = \rho A u^2$$
from conservation of momentum , the cannon recoils with the same force which it applies.
$$\quad \frac{dm}{dt}...
TL;DR Summary: I came across this question from a Sri Lankan A-level textbook.
Question - An ice cube with a length of 10 cm is immersed in water at 0 °C. An observer observes the ice cube from the water, and it seems to be 7.75 cm long. If the refractive index of water is 4/3, find the height of the ice cube immersed in the water.
I could not understand how the apparent height of the ice cube in the water depends on the height of the ice cube immersed in the water. Does anyone have an...
