Is Heisenberg principle applicable to a photon?
fluidistic
I wonder if Heisenberg principle (both \Delta p \Delta x \geq \frac{\hbar }{2} and \Delta E \Delta t \geq \frac{\hbar }{2}) can be applied to photons.
Say I have a laser emitting a flash. I know very well the wavelength of the photon, therefore its momentum. Also, I know well where it might be: it travels at c and must lie somewhere inside the cross section area of the laser beam situated at a distance ct from the laser, if I consider a time t after emission. Which seems to contradict that if I know well the momentum of the laser, I shouldn't know well where it is.
The same doubt arises with the relation between \Delta E and \Delta t. I know very well the energy of a laser photon since I know very well its wavelength. And I do so at any time...
Unless E\neq \frac{hc}{\lambda}...
So I don't understand if I'm missing something or if Heisenberg's principle cannot be applied to photons.
It applies to lasers. You don't know the wavelength as well as you think. Common notion is that a laser is monochromatic, and compared to natural light, "it is", but there is a uncertainty to the wavelength that prevents it to be perfectly monochromatic.
That explains everything... thanks a lot.
I think you will find the discussion in Landau, vol 4, section 1, "The uncertainty principle in the relativistic case" to be very illuminating.
"At first sight, one might expect that the change to a relativistic theory (of QM) is possible by a fairly direct generalization of the formalism of non-relativistic quantum mechanics. But further consideration shows that a logically complete relativistic theory cannot be constructed without invoking new physical principles..."
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
