Where Did I Go Wrong in Deriving Gravitational Potential Energy?
The discussion focuses on deriving gravitational potential energy from Newton's law using vector calculus. The user attempts to integrate the gravitational force but ends up with a result that is three times larger than expected. A key error identified is in the substitution step, where the differential change in a multi-variable function was incorrectly simplified. The correct approach involves acknowledging that the total differential should account for all components of the vector. The user acknowledges the need for a better understanding of multivariable calculus to resolve the issue.
Dead Boss
Derive the gravitational potential energy from Newton's law.
<br /> \mathbf{F} = -G \frac{m_1m_2}{\left|\mathbf{r}\right|^3} \mathbf{r}<br />
<br /> W = \int_A^B \mathbf{F} \cdot{} d\mathbf{r}<br />
<br /> \Delta{}U = W<br />
I can use the scalar version of the law, but I want to do it with the vector form.
So, first some easy substitution:
<br /> W = \int_A^B \mathbf{F} \cdot{} d\mathbf{r} <br /> = -Gm_1m_2 \int_A^B \frac{\mathbf{r}\cdot{}d\mathbf{r}}{\left|\mathbf{r}\right|^3}<br /> = Gm_1m_2 \int_A^B \frac{r_xdr_x + r_ydr_y + r_zdr_z}{\left|\mathbf{r}\right|^3}<br />
<br /> = -Gm_1m_2 \left\{<br /> \int_A^B \frac{r_x}{\left|\mathbf{r}\right|^3} dr_x +<br /> \int_A^B \frac{r_y}{\left|\mathbf{r}\right|^3} dr_y +<br /> \int_A^B \frac{r_z}{\left|\mathbf{r}\right|^3} dr_z<br /> \right\}<br />
Now take one integrand, for example the x part,
<br /> \int_A^B \frac{r_x}{\sqrt{r_x^2 + r_y^2 + r_z^2}^3} dr_x =<br /> \int_A^B r_x \left( r_x^2 + r_y^2 + r_z^2 \right)^{-\frac{3}{2}} dr_x<br />
and perform substitution:
<br /> t = r_x^2 + r_y^2 + r_z^2<br />
<br /> dt = 2r_x dr_x<br />
<br /> \frac{dt}{2} = r_x dr_x<br />
That yields:
<br /> \frac{1}{2} \int_A^B t^{-\frac{3}{2}} dt_x =<br /> \left[ -t^{-\frac{1}{2}} \right]_A^B =<br /> \left[ -\frac{1}{\sqrt{r_x^2 + r_y^2 + r_z^2}} \right]_A^B =<br /> \left[ -\frac{1}{\left|\mathbf{r}\right|} \right]_A^B =<br /> -\left( \frac{1}{\left|\mathbf{B}\right|} - \frac{1}{\left|\mathbf{A}\right|} \right)<br />
Doing the same for other two integrands and plunging them back:
<br /> W = -Gm_1m_2 \left\{<br /> -\left( \frac{1}{\left|\mathbf{B}\right|} - \frac{1}{\left|\mathbf{A}\right|} \right)<br /> -\left( \frac{1}{\left|\mathbf{B}\right|} - \frac{1}{\left|\mathbf{A}\right|} \right)<br /> -\left( \frac{1}{\left|\mathbf{B}\right|} - \frac{1}{\left|\mathbf{A}\right|} \right)<br /> \right\}<br />
And finally
<br /> W = 3Gm_1m_2 \left(<br /> \frac{1}{\left|\mathbf{B}\right|} - \frac{1}{\left|\mathbf{A}\right|}<br /> \right)<br />
Now if we take B at infinity, the potential energy will be
<br /> U = - 3G\frac{m_1m_2}{\left|\mathbf{r}\right|}<br />
which is three times as large as it should be. Don't tell me, let me guess. There's an error somewhere up there. *sigh*
Any help would be highly appreciated.
This is where you were wrong:
<br /> <br /> dt = 2r_x dr_x<br /> <br />
t is a multi-variable function, therefore: dt = 2r_xdr_x+2r_ydr_y+2r_zdr_z
A suggestion: 2\vec{r}d\vec{r} = d(\vec{r}^2) = d(r^2)
Thanks, hikaru!
I knew I should have read that book about multivariable calculus.
