Calculate the percentage of nitrogen in air
  • Thread starter Thread starter zorro
    Air Nitrogen
To calculate the percentage of nitrogen in air, the discussion emphasizes using the concept of additive gas volumes and masses. Participants suggest expressing the density of air as a function of the composition of nitrogen and oxygen. The key equation involves relating the total number of moles to the partial pressures of each gas, but some users express confusion about deriving the correct equation. A mass balance approach is recommended to express the mass of each gas in terms of its volume and density for clarity. The conversation highlights the importance of understanding gas behavior in mixtures to solve the problem effectively.
zorro
At 0C and 1 atm pressure the densities of air, oxygen and nitrogen are 1.293, 1.429 and 1.251 kg/m3. Calculate the percentage of nitrogen in air, assuming only these two gases to be present.
Which equation should we use here?
No one knows the solution??
Gas volumes are additive. If you mix some volumes of oxygen and nitrogen, final volume will equal sum of volumes, also final mass will equal sum of masses. Using this information try to express the density of the air as a function of composition (say assuming x fraction of nitrogen, and 1-x fraction of oxygen). Solve for x.
I tried to derive an equation but got stuck.
Can you just write the equation? That will help me in understanding the problem.
I would have to derive it by myself, I didn't.
Please show how you started and where you got stuck.
V = VO2 + VN2
nT/P = nO2/PO2 + nN2/PN2 ( as temperature is constant )
P = 1atm
Dividing the equation by nO2 + nN2
We get mole fractions on both sides.
On solving I get PN2 + PO2 = 1
which I don't think is of any use.
Abdul Quadeer said:
V = VO2 + VN2
OK
I told you to write mass balance - that is, express mass of each gas as a function of its volume and density. Pressure and temperature are of no use here.
Thanks a lot Sir!
I got it :smile:
Don't Sir me.
You may call me Mr. pH if you need to use a title.
:biggrin:
Sure, Mr. PH
