What Is the Gravitational Potential Energy of a Car on a 10-Degree Hill?
The discussion focuses on calculating the gravitational potential energy of a 1000 kg car at the top of a 10-degree hill. The height of the hill is determined to be approximately 8.816 meters using the formula Height = 50 * Tan 10. The potential energy is then calculated using the formula PE = Mgh, resulting in approximately 86,484.96 joules. The calculations are confirmed as correct by another participant. The thread emphasizes the importance of accurate height and mass in potential energy calculations.
tica86
Car has a mass of 1000 kg its at a the top of a 10 degree hill. so if you were to draw a triangle the the base of the triangle would be 50 M in length as well.
a)what is it gravitational potential energy relative to the bottom of the hill?
= 8.816
Potential energy =Mgh=1000 x 9.81 x 8.816 m=86484.96 J is this right?
hi tica86! :wink:
= 8.816
looks ok! :smile:
(is something worrying you about it?)
