Simple harmonic motion rise and fall of water
The discussion revolves around the simple harmonic motion of water in a harbor, with water depths fluctuating between 5.0 m and 9.0 m over a 12-hour cycle. To determine how long a ship requiring a minimum depth of 6.0 m must wait at low tide, it is noted that the amplitude of the tide is 2 meters. The ship can enter the harbor when the tide rises to at least 6.0 m, which occurs when the water level is 1 meter above the lowest position. Clarification was sought on a specific explanation regarding the oscillator's position, but the questioner ultimately understood the concept. The key takeaway is that the ship must wait until the tide rises sufficiently for safe passage.
thereddevils
The rise and fall of water in a harbour is simple harmonic. The depth of water varies between 5.0 m at low tide and 9.0 m at high tide. The time between sucessive low tides is 12 hours. A ship, which requires a minimum depth of 6.0 m approaches the harbour at low tide, how long the ship has to wait before entering the harbour?
A hint to start?
The time period of oscillations is given to you as 12hrs, the amplitude is (9-5)/2 = 2 meters, now for the tide to be at least 6m (minimum need for ship to pass), your oscillator must be 1m away from the lowest position moving toward the center.
Thanks Shivpal, but i don get the meaning of this sentence.
'your oscillator must be 1m away from the lowest position moving toward the center.'
Never mind, i got it.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
