Free-Fall Physics Problem: Position, Height, Time, and Speed of a Falling Brick
  • Thread starter Thread starter pjr65stang
    Free-fall Physics
The discussion revolves around a physics problem involving a falling brick from a height of 6.0 meters. Participants express confusion about how to approach the problem, particularly regarding the graph of position versus time and the calculations needed to determine the brick's height, time to reach the ground, and speed before impact. The key formulas for motion are highlighted, including the constant speed formula and the more complex distance formula that incorporates gravitational acceleration. A suggested method involves calculating the height at half-second intervals to create a comprehensive graph and answer the related questions. The conversation emphasizes the importance of applying the correct equations to solve the problem effectively.
pjr65stang
A load of bricks is lifted by a crane at a steady velocity of 5.0 m/s when one brick falls off 6.0 m above the ground. (a) Sketch the position of the brick y(t) versus time, from the moment it leaves the pallet until it hits the ground. (b) What is the greatest height the brick reaches above the ground? (c) How long does it take to reach the ground? (d) What is its speed just before it hits the ground?
I'm not sure where to even begin. The answers are in the back of the book, and the graph for part A is completely different than I thought. A time interval isn't given. I'm just really unsure of what to do here.
Welcome to PF!
We use formulas to describe the motion of a moving object.
When there is no acceleration, the formula is just d = v*t, where d is the distance, v the constant speed and t the time.
In this problem, there is the acceleration of gravity so the distance formula is more complicated: d = di + Vi*t + ½*a*t²
If you put in the initial distance di = 6, the initial speed for Vi and the acceleration of gravity -9.81 for "a", you can use the formula to find the height d at any given time. Do it for every half second from 0 to 3 or 4 seconds and you'll have enough points to graph the height vs time and answer the other questions.
