Is the Spontaneous Reaction of Hydrogen and Oxygen Dependent on Temperature?
  • Thread starter Thread starter Curl
    Hydrogen Oxygen
The discussion focuses on the spontaneous reaction of hydrogen and oxygen to form water, represented by the equation 2H2O --> 2H2 + O2. Participants inquire about the temperature at which this reaction becomes spontaneous, with one contributor noting that the auto-ignition temperature of hydrogen in air is approximately 530°C, depending on concentration. The concept of spontaneity is clarified, indicating that a spontaneous reaction occurs when the Gibbs free energy change (deltaG) is less than zero. A temperature of about 1750 K is mentioned as the threshold for spontaneity. Questions arise regarding the assumptions made for Gibbs values at different temperatures and the kinetics of the reverse reaction, particularly why hydrogen and oxygen do not spontaneously react at lower temperatures without an ignition source.
Curl
Hydrogen and Oxygen "burn"
Does anyone know the temperature at which this reaction becomes spontaneous?
2H2O--> 2H2 + O2
I can't find my book with thermodynamic data, but it should be cake for you guys.
Thanks.
Chemistry news on Phys.org
2H2O--> 2H2 + O2
Thanks.
What is the definition of spontaneity?
The auto-ignition temperature of hydrogen in air at STP is roughly 530'C depending on concentration and what not.
I think he just means at what temperature will a self-sustaining redox reaction occur.
The definition of a 'spontaneous reaction' is deltaG < 0, although I think sjb-2812 might've been asking that rhetorically.
The number I get for that is about 1750 K.
Thanks alxm.
I'm assuming you did this for 1atm pressure right? And how did you get the Gibbs values for the substances at those temperatures? Is it accurate to assume a linear relationship between G and temperature? Most tables I've seen offer values for 25C or so.
Also, what keeps the reverse reaction from happening at temperatures lower than this? I've seen H2 and O2 in a balloon and it didn't spontaneously react into water until a flame was brought up. What happens there? I haven't studied kinetics much, all I know is from stat mech.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
