Understanding classical stochastic systems
Classical stochastic systems are characterized by time-dependent random processes governed by standard probability laws, where the probability density function w(p,x,t) represents the likelihood of a particle being in a specific phase space region. In classical systems, randomness emerges from the inability to control experimental conditions precisely, leading to varying probabilities for different states. Unlike classical systems, quantum systems introduce inherent probabilities even under perfect control, as certain values of position and momentum cannot be simultaneously defined. The function w is non-negative in classical systems, reflecting the definite nature of particle states, while in quantum systems, w can be negative due to the uncertainty principle. Understanding these distinctions is essential for analyzing the behavior of particles in both classical and quantum frameworks.
spaghetti3451
This is an extract from my lecture notes:
"For classical stochastic systems, w(p,x,t)dpdx = prob. particle is in dpdx.
w\geq0 \int dp \int dx w(p,x) = 1."
1. Can anyone please explain what a classical stochastic system is?
2. Why is there a question of probability in analysing such a system?
failexam, Stochastic is just a fancy word for random. A stochastic system in physics is one that's governed by statistical mechanics.
The word 'classical' is in there because for a classical system x and p may be specified independently and take on any value, so you can speak of w(p,x) as a continuous function in phase space. For a quantum system only some values of x and p are allowed. For example for a harmonic oscillator, ½(p2 + x2) = nħ, and so the distribution in phase space is discontinuous.
In classical systems, randomness arises because of lack of experimental control. For example, the experimentalist may not be able to prepare the system in exactly the same state every time. He may only be able to prepare the system in some states with higher probability than others. This is how probability enters classical systems.
In quantum systems, even if the experimentalist has perfect control, probability still enters the physics.
Also, for a classical system, w is always greater than or equal to zero. Also, for a quantum system w is not always greater than or equal to zero, but can be negative. This is because a classical particle can have definite position and momentum. However, a quantum particle with definite position cannot have definite momentum.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
