How to bias a transistor into cutoff
  • Thread starter Thread starter zak8000
    Bias Transistor
To bias a transistor into cutoff, the user is analyzing a circuit with a collector cutoff current of 100nA. They performed DC analysis to derive the threshold voltage (Vth) and Thevenin resistance (Rth) equations. The user questions whether to assume the collector current (Ic) is slightly above 100nA to ensure the transistor operates in the active region before adjusting resistance values to achieve cutoff. The circuit is intended for RF applications. The user successfully resolved their query regarding the biasing process.
zak8000
hi
i would like to bias a transistor into cutoff. i have the schematic shown below and for the transistor i am using it has a collector cutoff current at 100nA. so my approach was frist to perform Dc analysis:
Vth=5*(R10/(R10+R4)) Rth=(R4*R10)/(R10+R4)
so my input equation is:
Vth=Rth*Ib+0.9+Ie*R12
and output equation is:
5=Vce+Ie*R12
i would ussually say Ie=Ib+Ic=(B+1)Ib but i don't think this equation holds at cutoff so should i assume Ic>100nA like 105nA so the amplifier will be in the active region(so i can use Ic=B*Ib) and then increase resistance values so Ic<100nA and the transistor will be in cutoff please help!
zak8000 said:
hi
5=Vce+Ie*R12
Looks like the schematic did not post. Can you try again? What is the application for the circuit?
ops i taught i attached it. anway i figured it out, it is used for RF applications
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
