Capacitor (the dissipation of electrical energy)
In an L-R-C series circuit with specific values for inductance, resistance, and capacitance, the average power dissipated in the resistor is 48.2W. The phase angle is 0.776 radians, and the power factor is 0.714, indicating the relationship between real and reactive power. The impedance is calculated at 329 ohms, with an rms voltage of 149V and an rms current of 0.453A. It is clarified that the average rate of electrical energy dissipation in both the capacitor and the inductor is zero, as these components store energy rather than dissipate it. This scenario exemplifies a common trick question in electronics exams regarding energy dissipation in reactive components.
jazzylady03
An L-R-C series circuit with an inductance of 0.116 , a resistance of 235 , and a capacitance of 7.25 carries an rms current of 0.453 with a frequency of 393 .
The phase angle is .776radians.
The power factor is .714
The impedance is 329ohms
The rms voltage is 149V
The average power is 48.2
The average rate at which electrical energy is converted to thermal energy in the resistor is 48.2W.
I need to figure out what the average rate at which electrical energy is dissipated (converted to other forms) in the capacitor?
and What is the average rate at which electrical energy is dissipated (converted to other forms) in the inductor?
Any help is GREAT!
The answer is 0 for both parts
This is an example of a common "trick" question that I've encountered on some electronics exams (like the one I took back in 1970 for my FCC license)...they give you voltages, frequency, component values, etc, then ask for the power dissipated in a capacitor (or inductor). The answer is simple: ZERO. Reactance stores energy, but does not dissipate it.
