Can I Charge Capacitors Without a Step-Up Transformer?
  • Thread starter Thread starter alpine2beach
    Capacitors Charge
Charging a capacitor requires a voltage source equal to or greater than the desired capacitor voltage. To achieve higher DC voltage from a lower DC source without a step-up transformer, voltage doubler circuits and charge pumps can be utilized. Charge pumps work by charging capacitors in parallel and discharging them in series, effectively increasing the voltage. These methods are particularly useful for applications like battery-powered devices. Understanding these concepts can help in designing circuits that meet specific voltage requirements.
alpine2beach
I know that in order to charge a capacitor, you must have a power source voltage greater than or equal to the desired voltage in the capacitor. Knowing this, is there any way to achieve a higher voltage DC(from a lower voltage DC) without using a step-up transformer?
Look up charge pumps.
triden said:
You might want to take a look at voltage doubler circuits. These are used in PC power supplies to convert 110 VAC to the 220 VAC that the supplies run on.
http://en.wikipedia.org/wiki/Voltage_multiplier
I need to use batteries, so AC is out of the question.
Thanks. That's pretty much what I need. Now all I have to do is figure out wiki... So basically a charge pump is a device that charges capacitors in parallel and discharges in a series?
Right.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
