Magnetic Circuits, Air Gaps (conceptual)
In magnetic circuits, if fringing is ignored, the flux density in the air gap equals that in the core, indicating uniformity in flux density across the circuit. The flux remains consistent throughout the series circuit, while variations occur in the permeability of different materials and the magnetizing force. This principle is supported by worked examples from provided resources. Understanding these concepts is crucial for analyzing magnetic circuits effectively. The discussion emphasizes the importance of these relationships in practical applications.
sandy.bridge
When dealing with magnetic circuits, if the question explicitly states to ignore fringing, then the flux density of the gap will equal the flux density of the core, correct? In fact, if there are ever more materials, the flux density throughout the entire circuit (series) will have the same flux, and flux density. The only thing that will vary is the permeability of each material as well as the magnetizing force, correct?
