Spring length hanging down and horizontal
A spring is longer when hanging down vertically compared to being horizontal due to the force of gravity acting on its mass, which causes it to stretch more. The discussion raises questions about whether the entire mass of the spring or just the portion below the equilibrium point contributes to this stretch. It is suggested that each coil of the spring bears the weight of the coils above it, leading to maximum stretching at the top. Additionally, the equilibrium point is noted to shift as the spring stretches under its own weight. Understanding these dynamics is crucial for analyzing spring behavior in different orientations.
dav1d
is a spring longer hanging down or horizontal
i think that the spring is longer hanging down because then its own mass contributes to the force of gravity, making it stretch more.
That is correct. When vertical, its own weight contributes to its stretch.
correct.
Would it be the springs entire mass? Or just the part under the equilibrium?
if it was only the part under the equilibrium then half of the spring would be stretched and half would be uncompressed right?
Each coil on the spring weights any coils above it. so you should have the most stretching at the very top, I think.
But doesn't the equilibrium point move as the spring stretches?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
