Exam: Measuring the Coefficient of Friction
To measure the coefficient of friction (μ), one common method involves using a force measuring device, such as a spring scale, to pull an object horizontally. This approach allows for calculating μ without needing to consider angles, as the force and mass provide the necessary data. Another method mentioned involves measuring the angle of incline (α) and using the formula μs = tan(α) to find static friction. The discussion seeks additional experimental ideas suitable for a university-level exam. Various techniques can yield accurate measurements of the coefficient of friction.
Faka
Hi everybody.
I am going to exam on Monday. I would like to make a experiment on how to measure the coefficient of friction.
I know, that I can find the mu(s), by taking the tan to the angle α.
μs = tan(α).
Is there somebody, who has some others ideas how to measure that? Somebody, who have done the experiment before. Maybe done it in a different way. It shall be university level.
I don't understand what experiment you are thinking of.
The usual way to measure μ is to use a force measuring device (spring scale?) to pull on an object. Knowing the force and the mass, you can figure out the μ. No angles involved if you pull horizontally.
