Quality factor of driven damped oscillating pendulum
The discussion revolves around calculating the quality factor (Q) of a cuckoo clock's pendulum, which has specific parameters including length, mass, and period. The user attempts to solve for Q using the relationship between the natural frequency, damping coefficient, and energy dissipation, but struggles with the required differential equations. They consider alternative methods involving energy calculations but find themselves needing more foundational equations of motion. The advice given suggests focusing on the fundamental definition of Q without delving into complex equations. Ultimately, the user seeks clarification on how to approach the problem without advanced mathematical techniques.
woodenbox
A small cuckoo clock has a pendulum 25 cm long with a mass of 10 g and a period of 1 s. The clock is powered by a 200 g weight which falls 2 m between the daily windings. The amplitude of the swing is 0.2 rad. What is the Q (quality factor) of the clock? How long would the clock run if it were powered by a battery with 1 J capacity?
F = ma --> d2θ/dt2 + γ*(dθ/dt) + (ω0^2)*θ = driving force***
ω0 = sqrt(k/m)
γ= b/m
Quality factor Q = ω0/γ
Also, Q = energy stored in oscillator/energy dissipated per radian
ω0 = T/(2*pi) = 1/(2*pi)
Using arclength s and angle θ, m(d2s/dt2) = -mgsinθ, and since s = L*θ where L is the length of the pendulum, m*L*d2θ/dt2 = -mgsinθ - b(dθ/dt) + driving force
driving force = weight of falling mass = mg = .2*g
work done by driving force = .2*g*2meters = .4*g
the resonance width of the system = γ, and occurs when ω - ω0 = ±γ/2
I think that using the initial conditions given, I should be able to solve for ω somehow and then, having already solved for ω0, use ω - ω0 = ±γ/2 to solve for γ, and then Q would just be ω0/γ. However, solving for ω would require solving the second order non-homogeneous differential equation starred (***) above, and this class isn't supposed to require knowledge of ODEs (goes up to Calc IV).
The other option is to use energy and use the fact that in the steady state, the energy lost is all lost by the damping force, but this would again require having an equation of motion for x from which to get dx/dt, from which to find the energy lost by the damping force -bv, so I'm still at a loss of how to do this without actually solving for the equation of motion.
Any help would be greatly appreciated!
Thank you.
You don't need to solve any fancy equations to handle this problem.
Start with the actual fundamental definition of Q. State this in words, not using any symbols or equations at all.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
