Is the Gradient Vector Always in the Radial Direction?
seshikanth
As we know grad F (F surface) is in normal direction. But we also have (grad F(r)) x r = F'(r) (r) x r = 0
this implies grad F is in direction of r i.e., radial direction. Radial and normal directions need not be same. Can any öne clarify THE DIRECTION OF GRAD VECTOR?
Gentle reminder
In your second formula, you refer to "F(r)" so you are assuming that F depends only on r and so is spherically symmetric. The first formula does not assume that .
Got it! Thanks!
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
