How do I find velocity when force is not a constant?
To find velocity when force is a function of distance, the equation F(x) = 2.5 - x^2 leads to acceleration a = (2.5 - x^2)/m. While integrating acceleration directly with respect to position yields an incorrect expression for velocity, the correct approach involves integrating acceleration with respect to time. The integration property allows for factoring out constants, but the key is recognizing that velocity is derived from acceleration over time, not position. Utilizing the chain rule may be necessary to correctly relate these variables and find the velocity. Understanding these principles is crucial for solving the problem accurately.
DBaima22
how can i find velocity if force is not constant, but a function of distance. I tried integrating the equation for the force, but that doesn't account for the mass of the object.
the given equation for the force is F(x)=2.5-x^2, where x is distance and since F=ma I have
a=(2.5-x^2)/m.
When I tried integrating it I got velocity= -1/3x^3+2.5x which does not account for mass
Is there a quotient rule for integration?
Welcome to PF, DBaima22 :smile:
a=(2.5-x^2)/m.
It's completely reasonable to assume that the mass of the object is constant. Therefore, this becomes trivial. You can use the relevant integration property, namely that if g(x) = f(x)/a where a = const. then:
\int g(x)\,dx = \int \frac{f(x)}{a}\,dx = \frac{1}{a}\int f(x)\,dx
If something is constant (i.e. it has no dependence on the integration variable), then it can be brought outside the integral.
So, just to be clear, if acceleration is (2.5-x^2)/m. I can write velocity as
v= -1/3x^3+2.5x/mass?
Yes. BUT there is another problem with your solution that I only just realized (because I wasn't paying close enough attention before). You CAN'T get velocity by integrating acceleration with respect to position. Velocity is the integral of acceleration with respect to TIME. So you'll have to work a little bit harder to figure out how to get velocity. :wink: Hint: the chain rule may be of use here.
