Has Anyone Explored 3D Number Scattering?
EG
has anyone investigated the three-d scattering of numbers?
FYI:
for any base
take the symbols that represent the numbers
arrange them in a rectangular or square grid
from a starting point, follow them in a square, rectangle, or diamond until you construct a number of 2n digits
divide by a number consisting of n "1" ' s
and there is no remainder.
Probably falls out of some other findings, but an interesting construction.
EG
This construction works in any base
I conjecture in any dimension as well
Anybody got a proof?
Is the construction understood?
I don't understand the construction.
"take the symbols that represent the numbers"
Do you mean digits?
"arrange them in a rectangular or square grid"
Like 0 1 2 3 4
5 6 7 8 9 ?
"from a starting point, follow them in a square, rectangle, or diamond until you construct a number of 2n digits."
I Think you mean like 78901234 with n= 4.
"divide by a number consisting of n "1" 's and there is no remainder"
Dividing that by1111 gives 71018 with remainder 236 so apparently I don't understand.
1 2 3
4 5 6
7 8 9
construct 12369874
or 123654
or 5698
divide 12369874 by 1111 = no remainder
divide 123654 by 111 = no remainder
divide 5698 by 11 = no remainder
or, arrange them in a cube:
5 6
1 2
7 8
3 4
construct 1562 / 11 = no remainder
construct 2684 / 11 = no remainder
etc
is this a trivial result of n-dimensional matrix arithmetic?
What apparent nonsense:
1245 and 1254 are both seemingly constructible in the first example, and they can't both be divisible by 11, can they?
Oh, the examples you picked work for obvious reasons once you know that a number is divisible by 11 iff the sum of the 1st, 3rd, 5th etc digits minus the sum of hte 2nd, 4th, 6th etc digits is also divisible by 11.
what about 123658 in your example with 9 numbers in a square?
I still don't understand the construction.
Actually 1254 is divisible by 11. And it appears to me that 1245 cannot be constructed from his diagram.
From the first diagram, he says draw an imaginary line through the numbers until you form a square, starting from any digit, either clockwise or anti-clockwise:
123
456
789
The chosen numbers are bolded. The line passes through 4 digits, hence it passes through 2n digits where n=2. The starting digit does not seem to matter. Divide the number formed by a digit consisting of n "1s", in this case 11. 11|1254
I tried some other combinations:
123
456
789
whether anti-clockwise or clockwise it does not seem to matter, just like the starting digit. All the combinations of the six chosen numbers above are divisible by 111 (n=3, since it passes through six digits). Taking it diamond-wise:
123
456
789
Going clockwise or anti-clockwise yields 4 digit numbers alll divisible by 11. The only problem I have is how the digits in the construction of the diagram is to be arranged. Can someone explain how this works? I have no idea.
EDIT: The following is his cube:
Going through the the same process seems to yield numbers divisible by n "1s".
why is 1245 not allowed? the construction is completely permissible in the sense of he has said nothing to disallow it. "follow them in a square" is ungrammatical and ambiguous - and who's to say how the digits should be writtend out in the first place? Why is
543
612
789
Not acceptable?
The arrangements you are allowing have their entries as arithmetic progressions (mod 10) You should see why that makes it work in the special cases given.
This is something he would have to reply to. I have no idea how the diagram is to be constructed to begin with.
The allowed constructions are only those which form a "closed loop"
123
456
789
123654 is allowed
123658 is not
1254 is allowed
1245 is not
etc.
matt grime wasn't referring to the loops that can be constructed, but how the diagram is to be drawn in the first place.
Oh, I was referring to all of those things including what shapes can be constructed seeing as the post was ambiguous to say the least. As it is what you're doing is disguising some obvious modulo arithmetic.
What about 12369854?
4 5 6
7 8 9
10 11 12
And I say my number system is base 13. Then it will not work.
But if I re-represent 10 as 1+0 = 1, 11 as 1+1 =2, and 12 as 3, and so on,
it works.
EG, is this a numerology trick/question?
okidream said:
1 2 3
4 5 6
7 8 9
10 11 12
It works for 1254 , it works for 5698 , it works for 2684, and so on.
It seems any arragement that works in base 10 , works in base 13, too.
Here's a pretty simple proof of the case for rectangular loops. This is specific to base 10, but it can be easily generalized:
The array of numbers looks like this:
1 2 3 ... d
d+1 d+2 d+3 ... 2d
Where there are d numbers in each row. Now the rectangular loop, which has length 2n, looks something like this:
[x] [x+1] [x+2] ... [x+k]
[x+d] x+d+1 x+d+2 ... [x+d+k]
[x+2d] x+2d+1 x+2d+2 ... [x+2d+k]
[x+l*d] [x+l*d+1] [x+l*d+2]... [x+l*d+k]
Where the bracketed terms make up the number, with x being the first digit and x+d the last. k and l are the width and height of the rectangle. The (n+1)th digit is x+l*d+k, and the sum of the first and (n+1)th digit is 2x+l*d+k. The sum of the second and (n+2)th is (x+1) + (x+l*d+k-1), which is 2x+l*d+k. It is easy to see that the sum of the ith digit and the (i+n)th digit is always 2x+l*d+k, which from here on I'll call 'm'. Also, from here on I'll call the ith digit di. So d1=x, and di+di+n = 2x+l*d+k = m.
Now the number, which I'll call N, can be put in the form:
N = 10^n x + y
where:
x = d_1 10^{n-1} + d_2 10^{n-2} + ... + d_n
y= d_{n+1} 10^{n-1} + d_{n+2} 10^{n-2} + ... + d_{2n}
We know that 111...11 with n 1's divides 10n-1. So if it divides N, it must also divide:
N -(10^n-1)(x)= 10^n x + y-(10^n-1)x = x + y
which is:
(d_1 10^{n-1} + d_2 10^{n-2} + ... + d_n ) + (d_{n+1} 10^{n-1} + d_{n+2} 10^{n-2} + ... + d_{2n})
= ((d_1+d_{n+1}) 10^{n-1} + (d_2+d_{n+2}) 10^{n-2} + ... +(d_n +d_{2n} )
= m 10^{n-1} + m 10^{n-2} + ... + m
= m (111...11)
which completes the proof.
edit: this also works if the string starts somewhere else in the loop or goes around the otherway. all this changes is which sums are in which decimal places, but since theyre all m anyway, you get the same result.
edit 2: I just thought of a few generalizations. This will work for any shape constructed like so: Make a contour with n squares. Copy it, rotate it by 180 degrees, and put the second piece wherever you want (use it to form a closed shape if you want, but you don't need to). The number is formed by starting at any point on one of the contours and continuing in one direction around it and in the same direction around the rotation until you get back to where you started. This covers the diamond shape.
I admit this is a little confusing. Here's an example: if your shapes are Ls, you could start at the corner of one L, go up the long side, than across the short side of the other one, down its longs side, and finally across the short side of the original one to get back to the start. The second L must be rotated by 180 degrees, but could be anywhere you want it. They could form a rectangle, not touch at all, or overlap, just as long as you go around the right way.
This number will have 2n digits, and is divisible not just by 111...11 with n ones, but also with k ones for any k that divides n.
Like I said a page ago, it's simply a fact about arithemetic sequences mod 10, or whatever base you chose to work in.
Yes, well, could you explain to me how it is "obvious"?
Thanks
We have done. For example
123
456
789
pick any element, x, then the digits are, say, x, x+1, x+3,x+2, if x is one of 1,2,3,4 then obviousl the 4-digit number yo formed is divisble by 11. A similar analyisis works for other patterns and numbers. It is because of the arrangement of the arithemetic sequence.
I tried a filling in a few grids and this system worked every time
The grid can be any rectangular (including square) or solid such that all corners are ninety degrees. The number of vertices of the grid must be less than the base of the numbering system you are working with. Select an order to follow consistently such as left to right, top to bottom, front to back, and fill in each row seqentially starting with 1 following the chosen method. If you selected left to right, top to bottom, and front to back as your order you must fill in each row, left to right starting at the top and working down until you cover the front face then repeat this process with each sucessive layer behind the front layer.
