What is the relationship between speed and acceleration in simple terms?
  • Thread starter Thread starter moatasim23
    Acceleration
Acceleration is defined as the rate of change of velocity over time, which can be expressed mathematically as a = v/t, where 'v' is speed and 't' is time. The relationship between speed and acceleration indicates that acceleration is the change in speed per unit of time. In simpler terms, if an object speeds up, it has positive acceleration, while slowing down results in negative acceleration. The equation provided, s^2 = at^2 + 2bt + c, relates distance, acceleration, and time, illustrating how these concepts are interconnected. Understanding these relationships is essential for grasping the fundamentals of motion in physics.
moatasim23
The distance covered by an object is given by the equation.
s^2=at^2+2bt+c
Then acc varies as?
I am a beginner please some one explain in the simplest language possible.
What is the relationship between speed and acceleration?
Hint - look at your equations.
a=v/t
v=s/t
therefore: a=(s/t)/t = s/t^2
specifically - acceleration is the second time-derivative of displacement.
what sort of answer is expected depends on where you are at in your studies.
