How does the weight of a fish affect the stretching of a steel wire?
  • Thread starter Thread starter usamo42j
    Steel Wire
The discussion centers on calculating the stretching of a steel wire when a 4.50-kg fish is hung from it, along with additional work calculations when the fish is pulled downward. The angler seeks to determine the wire's stretch using Young's modulus, but encounters difficulties in calculating the work done by gravity and the force exerted by the wire. Key equations include Young's modulus, which relates tensile stress and strain, and the need for proper unit conversions, particularly from kilograms to Newtons. The applied force can be inferred from the additional stretch of 0.500 mm when the fish is pulled. Clarification on wire length and additional force details is necessary for complete calculations.
usamo42j
An angler hangs a 4.50-kg fish from a vertical steel wire and 5*10^-3 cm^2 in cross-section area. The upper end of the wire is securely fastened to a support.
a) Calculate the amount the wire is stretched by the hanging fish.
The angler now applies a force F to the fish, pulling it very slowly downward by 0.500 mm from its equilibrium position.
Calculate
b)Work done by gravity
c) Work done by the force F
d) Work done by the force the wire exerts on the fish
e) Change in elastic potential energy
Young's modulus = Tensile stress/tensile strain=F/A*l0/Δl
Newton's laws (?)
Young's modulus for steel is 20^10 = 4.5g/(5*10^-7)*1.5/Δl and solve for Δl
Then the work done by gravity is 4.5g*0.500/10^3
But it doesn't seem like there is enough information about the forces to answer c) and d)... I tried setting the force equal to the weight, but that didn't work.
Help is appreciated. ~
Don't forget proper units and conversion factors. Force is in Newtons, not kg. What is the wire length and units?
The applied force can be determined by the fact that the wire stretches another 0.5mm when it is applied.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
