Maximum charge and voltage on a sphere
The discussion centers on calculating the maximum charge and potential of a spherical conductor with a radius of 2 cm, where electrical breakdown occurs at an electric field of 3.0 x 10^6 Vm^-1. The maximum charge calculated using the electric field equation is 13μC, leading to a potential of 585kV on the sphere's surface. However, a correction reveals the radius should be 20 cm instead of 2 cm, which affects the calculations. The participants express uncertainty about the viability of the initial answers and the need to consider the correct radius. Accurate calculations are essential for determining the maximum charge and potential accurately.
shyguy79
Hi guys, doing an assignment question
A spherical conductor filled with air with a radius of 2cm is supported in the air. Electrical breakdown occurs when the electric field reaches 3.0 x 10^6 Vm^-1
(a) What is the maximum charge that can be placed on the sphere?
(b) What is the value of the potential on the surface of the conductor when carrying maximum charge
E(r) = 1/4∏ε0 x Q/R^2 where 1/4∏ε0 = 9x10^9, Q = charge and R^2 =radius of sphere 0.2m
V(r) = 1/4∏ε0 x Q/R
Ok, so for the (a) then using the equation for electric field E(r) rearranged for Q
Q = (E(r) x R^2)/9x10^9 =(3.0 x 10^6 Vm^-1 x 0.2^2)/9x10^9 = 13μC
Seems realistic? Just not sure of the next bit...
V(r) = 1/4∏ε0 x Q/R = 9x10^9 x (13x10-6C / 0.2m) = 585kV
585kV? Something has gone wrong... is this a viable answer or should I be taking into account the area of the sphere...
V(r) = 1/4∏ε0 x Q/R
2cm = 0.02m , not 0.2m
Thanks for the heads up - that should have read
spherical conductor filled with air with a radius of 20cm
