Strange question about an AWD hand car
  • Thread starter Thread starter justinpba
    Car hand Strange
The discussion revolves around designing a pedal-powered hand car for a race, with a focus on the advantages of all-wheel drive (AWD) versus rear-wheel drive (RWD) or front-wheel drive (FWD). The primary concern is the mathematical efficiency of power transfer and traction, particularly since the car will be on train tracks. It is suggested that a continuously variable transmission could optimize power delivery, and that minimizing chain length is crucial for weight distribution and efficiency. Additionally, exploring rowing motions for propulsion is proposed as a potentially more effective method than pedaling. Ultimately, unless traction is a significant issue, a 2WD system may be more energy-efficient than AWD.
justinpba
Hi all! I'm new here. I'm a mechanical engineering student at ODU and I'm designing a hand car. Yes, like the ones that ride on train tracks. This is being designed for the Santa Rosa California Hand Car Regatta and will be pedal powered. The HCR is part art show/part drag race and I'm building it to race. My question is: is there any mathematical advantage to having the car be AWD vs RWD or FWD. There will be 2 riders and I'm thinking of setting one up to power each axle. All other calculations are being made regarding material, thicknesses, stresses and what not to minimize weight and maximize speed, but I don't know how to calculate what the best drive configuration would be. Consider that either setup will require the same parts and weight. Thanks for any help!
-Justin
Anybody? Mathematical formula for which will transfer more power over short distance AWD or RWD is all I'm really asking for.
Only if you have issues with traction.
Otherwise the axles can be considered mechanically coupled by the rail.
Okay. Thanks. Now as a follow up, because it will be pedal driven via a chain, for weight distribution purposes would it be best to minimize chain length and position a driver at each end and operate via AWD? My concern that if weight is evenly distributed via RWD that would require placing both operators at the center of the car, but that would increase power loss due to a longer chain. Both operators are of similar weight. Again, any help is greatly appreciated.
I think the more important issue is the efficiency of delivering power from the source (the two people driving the cart). At too slow and too fast a pumping/pedaling speed your people will be inefficient at delivering their maximum power. So the goal would be to find the optimum gear ratio that let's them work comfortably and efficiently to propel the cart down the track. Unfortunately, the cart will be going at different speeds (starts at 0, ramps up, etc...): That's where different gears ratios come in, just like for a car engine, to keep it working in it's optimal range.
It seems that for something like this, a continuously variable transmission may work out, since it doesn't have to handle too much force. Maybe you could pickup a small one from a junkyard and hack it to work on your cart?
Another idea is that instead of pedaling, look into rowing motions; it seems to me that rowing motions are more natural for humans and you might get more power out from the drivers. Maybe hook up with a physiology major for some ideas?
To your original question, I don't see much advantage to using 4wd over 2wd, unless you think the track is "slippery". If the latter, add a thin rubber sleeve around the drive wheels (like from a strip of bicycle tire tube) to increase friction. Since it's human-powered, you'll want to minimize energy loss; you'll loose more energy in a 4WD system than a 2WD system
fwiw.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
47K
