Noether Current Derivation for SO(3) Rotation?
ClaraOxford
This is a problem from my theoretical physics course. We were given a solution sheet, but it doesn't go into a lot of detail, so I was hoping for some clarification on how some of the answers are derived.
For the Lagrangian L=1/2(∂μTμ∅-m2T∅) derive the Noether currents and charges.
jμa=∂L/(∂(∂μa))*\Phi - \Lambda\muα
Here, the lambda term is zero, because the Lagrangian is invariant under SO(3).
a → ∅a + \Phiεα
We were first told to show that the above Lagrangian satisfies SO(3) symmetry (this was fine). The solution sheet then states that infintessimal transformations can be written as ∅a → ∅a-itc(Tc)abb, where (Tc)ab=-iεcab
I could not work out how to derive this though.
Using the above info, I can see that \Phiac = -i(Tc)abb, taking εα = tc
Then I just need to calculate ∂L/∂(∂μa)
Is this just ∂μa?? I'm not sure how to calculate this when there's 2 derivatives, one with a superscript and one with a subscript. And does the transpose affect things?
You probably want {j^\mu}_\alpha on the left side to match indices.
You could either take this as a definition of the Lie algebra of the orthogonal group or else show that the finite matrices \exp (i t^a T_a) are orthogonal. This is a generalization of the way we can parametrize 2d rotations by an angle.
You can write
\partial_\mu \phi^a \partial^\mu \phi_a = \delta_{ab} \eta^{\mu\nu} \partial_\mu \phi^a \partial_\nu \phi^b,
then use
\frac{\partial}{\partial(\partial_\nu \phi^b) } \partial_\mu\phi^a = \delta^a_b \delta^\nu_\mu.
Since there are 2 factors of \partial\phi, you'll need to use the product rule which brings in a factor of 2 in the answer.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
