Error tolerance in coil design (number of turns)
The discussion focuses on designing a coil with 2100 turns of 30AWG wire, considering the impact of heavy insulation on wire diameter. The calculated wire length is approximately 8,420 inches, but real-world variations may affect this estimate. Participants suggest allowing for error tolerance by having extra wire on hand, as precise calculations can be challenging. The choice between layer wound and random wound methods is also debated, with considerations for insulation and fill percentage. Ultimately, ensuring enough wire for the winding process is emphasized as a practical approach.
hobbs125
I am designing a coil which will have 2100 turns of 30AWG wire.
The bobbin diameter is 1.045" and the length is 1.28"
From my calculations I will use about 8,420 inches of wire.
I tried an online calc but they did not take into account that the wire I am using has a heavy insulation so it's diamter is about .0115".
As we know things is the real world are usually somewhat different.
My question is how much of an error tolerance I should expect in terms of wire length for the 2100 turns? And should I expect to use more or less wire than calculated?
Any help/suggestions would be greatly appreciated.
Layer wound or random wound?
If layer what is layer insulation?
If random wound, depends on winder. Assume maybe 60% fill?
Is this a math exercise? Like how many balls can you fit in a can?!
Just get extra wire and wind it, point is you want to have extra to make sure you have enough!
You could go back to the online calculator and tell it you have 26 gauge wire. This has a diameter of 0.0159 inches which is close enough to your wire with its thick insulation.
But it is an imprecise business and difficult to calculate exactly, so you do need to have some spare wire.
The main problem may be how many turns you can fit on your bobbin.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
